DIY UPS for Home Assistant Green & Xfinity XB7 Modem
A 12V LiFePO4-based uninterruptible power supply for keeping a Home Assistant Green and Xfinity XB7 cable modem running during grid outages. Built into an IP65 enclosure with Home Assistant monitoring via Shelly Plus Uni.
Honest context: A $75 APC BE600M1 would do the same job out of the box. This build costs roughly $200 more over 10 years than that option. The engineering rationale — longer battery life, faster switchover, direct HA integration, no DC-DC converter voltage regulation — is documented in https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/design-rationale.md. Build this if those tradeoffs matter to you.
System Overview
AC grid powers a Mean Well LRS-100-12 PSU set to 13.3V float, which charges a 12V 10Ah LiFePO4 battery through a MOSFET ideal diode. On grid failure, loads switch directly to battery in under 1ms. A Victron BatteryProtect BP-65 disconnects loads at 11.8V to prevent over-discharge. A Shelly Plus Uni reports battery voltage and temperature to Home Assistant.
AC Power (Wall)
│  Mean Well LRS-100-12 PSU          │
│  Input: 85-264VAC  Out: 13.3V      │
                 │ 13.3V (float)
│  Pololu Ideal Diode (4-60V, 10A)   │
│  Prevents PSU backfeed from batt.  │
│  Cyclenbatt 12V 10Ah LiFePO4       │
│  Built-in 10A BMS, 5000+ cycles    │
│  Victron BatteryProtect BP-65      │
│  LVD: 11.8V (Setting 7)            │
│  Reconnect: 12.8V, 90s delay       │
                 │ 11.71–13.16V at device terminals
         [F3:2A]    [F4:5A]
         HA Green   XB7 Modem
           (3W)      (~14W)
│  Shelly Plus Uni (Monitoring)      │
│  ADC → Battery Voltage             │
│  GPIO → DS18B20 Temperature        │
│  WiFi → Home Assistant             │
Key Specifications
ParameterValue
BatteryCyclenbatt 12V 10Ah LiFePO4
Float voltage13.3V (set on PSU trimmer)
LVD cutoff11.8V (Victron BP-65, Setting 7)
LVD reconnect12.8V (30s delay after threshold met)
Device voltage envelope11.71–13.16V at terminals
Switchover time<1ms (MOSFET ideal diode)
Typical load~17–18W combined
Runtime at typical load~6.3 hours
EnclosureLeMotech IP65 ABS, 9.6″×7.6″×4.5″
MonitoringShelly Plus Uni → Home Assistant
Total build cost~$234
Operating Modes
Mode 1 — AC Present: PSU outputs 13.3V through ideal diode; battery held at float equilibrium. Loads draw from PSU, not battery.
Mode 2 — AC Failure: PSU output drops to 0V. Ideal diode blocks. Battery feeds loads directly, no interruption.
Mode 3 — Low Battery (~12.2V): Shelly detects threshold via ADC. Home Assistant initiates graceful HA Green shutdown; modem continues on battery.
Mode 4 — LVD Cutoff (11.8V): Victron BP-65 disconnects loads after 90-second hold-off.
Mode 5 — AC Restoration: PSU resumes 13.3V, ideal diode switches source, BP-65 reconnects after 30s hold-off.
Assembly Layout
Component Layout
Elevation (top) and plan (bottom) views of LeMotech junction box. Dimensions in inches.
Documentation
FileContents
https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/bom.mdFull bill of materials with vendor, price, and notes
https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/wiring.mdFrom/To wiring tables, fuse locations, component mounting
https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/specifications.mdElectrical, performance, and protection spec tables
https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/design-rationale.mdBuild-vs-buy analysis, float charging strategy
https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/component-selection.mdPer-component selection rationale
https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/cost-analysis.mdBuild cost breakdown and 10-year lifecycle comparison
https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/safety.mdAC and battery safety procedures
https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/voltage-drop-analysis.mdWiring resistance and voltage drop calculations
Datasheets
Status
Notes
  • Device input voltage tolerance (±10%) is inferred from IEC 62368-1 design practice; neither Nabu Casa nor Comcast publish explicit DC input voltage ranges for these products.
  • The PSU output trimmer is set to 13.3V and lacquered. Drift analysis shows expected aging drift of 3–5 mV/year — negligible relative to the 500mV headroom before OVP.
  • No DC-DC converter is used. The direct battery feed strategy is documented in https://github.com/wkcollis1-eng/DIY-LiFePO4-UPS/blob/main/docs/design-rationale.md.
