• Thermionic tube
    Quasi Scientist • 2 days ago • 0 comments
    Combine hot filament and high voltage and get, thermionic tube
  • Diode
    Quasi Scientist • 10/04/2026 at 05:31 • 0 comments
    I've made a video of simple diode. As part of building CRT. Basically I have filament and gate. Gate is connected 60volt and resistor. I've measured the voltage drop on resistor.
    I've got 2.5v without burning filament, I could try more but didn't want to ruine the diode.
    Filament is heated with about 2.5volt (with about 5amperes, yeah it's not very efficient light bulb)
  • Hot cathode CRT
    Quasi Scientist • 08/21/2026 at 19:51 • 0 comments
    I was succesful at making a simple tube with tungsten wire. I've put voltage of only few thousands volts. Nothing happens once fillament get hot I see plasma. Just as I expected.
  • Geissler Tube
    Quasi Scientist • 06/29/2026 at 14:57 • 0 comments
    To make Geissler tube you need to go to at least medium vacuum (in my case ~1Torr). Without it you will not get Faraday's dark space.
    Here you can see Faraday's dark space on right and positive column on left
  • Light bulb
    Quasi Scientist • 06/10/2026 at 14:49 • 0 comments
    Although, it seems like very standard (everyone has it at home), it VERY tricky to make. The reason is for that is hot cathode instead of cold one. In cold cathode mode it's OK to use glue to seal tubes and connect feed through electrodes. It getting a little bit warm but it doesn't leak. Here the electrodes gets very hot. As this light bulb is 12Volt at 3 Amperes. (Which makes it 36 Watt bulb)
  • DIY Crooke's tube
    Quasi Scientist • 06/06/2026 at 21:06 • 0 comments
    It turned out that building Crookes tube is quite easy. All you need is some basic glasswork, epoxy glue, beer bottle and 3D-printed part for better hold cathode. Connect everything together and apply vacuum. Once it reaches certain level it will shine more and more. Then you can place a magnet to see how electron deflected from magnet.
  • Magnetic lens
    Quasi Scientist • 05/10/2026 at 13:45 • 0 comments
    Magnetic lens is really cool concept! Here is Crook's tube I've bought (was not able to make by myself yet) and magnetic lens was added. Actually it is a simple coil. By varying voltage, hence current in the coil. The spot can be concentrated to about 2mm
  • Florescent tube
    Quasi Scientist • 04/01/2026 at 15:53 • 0 comments
  • Simple nixie tube
    Quasi Scientist • 03/02/2026 at 15:43 • 0 comments
    I've bought simple 0.3Pa vacuum pump which seemed to be reliable. I've pumped the air out until the glow turned to dim blue. Then I've cut close using standard torch. It's amazing! I feel the video doesn't show how really beautiful it is.
    Another interesting thing is how glow change when tube depressurized. The color change from dim blue to red through white bright
    Note: Most of sites/video like jdflyback and simplifier use metal to glass connection. I was not able to make one which not leaked. Instead I've used different heat resisstent glue. It is success and was not leaked yet.
