Final testing for V1
A project log for Opencooler
A compact water chiller/heater that can function as a drop-in alternative to cooling mattresses like 8Sleep + other purposes (lab).
patPat 6 hours ago0 Comments
I am moving countries again. This is a final test assembly before I toss the bulky stuff and pack everything I own into a single suitcase. The test did not go as I was hoping, and there are still a lot of things to refine.
The chinese splitters I was using I believe had a short, which causes some magic smoke with the controllers. I did get some useful results though, I'll do a quick summary below.
I should probably stop trying to build the entire thing around this heatsink design....
Quick connectors worked well! Screen did not. Power switch works after switching the breaker x1. Black segment was an extension because it had to be longer to fit the separate pump because of the leaking reservoir from the last post. Black and white looks sick though, so happy accident.
So I think in conclusion, 8Sleep pod is pretty close to the optimal layout already. There's a reason they aren't laid horizontally. I think the V2 will be a cuboid. See you in a few months when I have (hopefully) a new workshop. I do not know where I am going yet, just that I am leaving in three weeks. Might be longer.
