The project is compatible with the 8-bit Workbench™ extension bus and can connect to other projects of mine:
  • 8-bit Workbench™; an annotated 8-bit display that talks hexadecimal and octal. An Action-button provides a properly de-bounced signal to use with microprocessors or TTL logic.
  • Super Breadboard; enjoy short circuit protection. Have both +3.3V and +5V at hand. Clearly separates data input and output of your prototype. Can work standalone as well.
  • Binary Keyboard; adds a retro 8-bit toggling experience to your experiments.
  • Hex Keyboard; turn-in a hexadecimal code (0-F) for the high- and the low-nibble. The output, a full byte (8-bits), can then be used with attached experiments. Supports a Logic Probe as well.
These are all available as kits.
More information is on my website.
