Fixing the tip over.... More failure
A project log for Electric Tracked Tricycle for EMF camp
I wanted to buzz around 2024 EMF camp in something different. So I designed and built an electrically powered, tracked tricycle.
tony-goacherTony Goacher 04/17/2026 at 10:100 Comments
There's a video on this part of the build here.
Testing had previously highlighted two issues:
To fix the first I started by removing the track mounting plates.
And then cut and notched a longer square section to fit over the round bar chassis.
And then welded this longer section back onto the chassis.
It's noticeably wider with this in place. Fortunately I checked the new width with that of my cars boot/trunk before committing.
In an attempt to improve starting I swapped out the stock motor controller for more sophisticated VESC 75100 clone. These have a serial PC interface that allows acceleration and power settings to be configured.
And so with these changes it was time for another test.
Stability was massively improved and starting seemed better, but still not quite right. I definitely had fun during the test though.
I'll just tweak the motor controller settings a little. And that was it. Both controllers failed. Didn't even show up as a serial port in the configuration software.
So with 2 weeks to go to EMF camp, I'm getting worried.
