3D Printer - T24 (2019)
First use of ballscrews
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Found a vendor called Phidgets who has a nice selection of linear motion parts for a good value, especially the hollow steel rails. This design could be revisited since it mainly needs flushing out in the design and 4 Z screws, not 2.
Learned way later that 5mm pitch is too slow unless you are capable of 3k rpm or better.
