Quick try at a parallel robot arm, or as Marlin calls it, a Tpara.
If you ever need a very sturdy base bearing, use a wheel hub (wheel bearing) off a Toyota or larger as needed. Lifetime grease, stupid strong, and easy mounting as long as weight isn't critical. The drive axles are splined if that is needed.
