3D Printer - T108V2 (2024)
Be there or be square, but now copper plated
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A more flushed out variant of T108 using igus bushings lying around. As said on a prior design, Type M copper tube generally holds a very tight diameter tolerance, so it makes a great bushing-only linear rod and quite light due to being thin.
This design using steel cable for the Z to keep things compact in a way, even if more complex.
