CYR PIVOT-FIELD GENERATOR
Hackaday.io — Digikey Green Powered Challenge
Submitted: March 19, 2026
Author: Alan Cyr / Wolf13 · CYR Technologies · Chicago, IL
FINAL ARCHITECTURE — No further mechanism changes anticipated
PROJECT OVERVIEW
A cog-bypass mechanism for rotating permanent magnet generators that recovers
3-8% of output currently wasted overcoming magnetic alignment (cogging) torque.
Two variants documented: Individual Pivot Holder and Ring Axial Travel.
Core principle: extract at the phi offset (38.17° before stator pole dead
center) where peak EMF occurs naturally — not at dead center where cog force
peaks. The field does all the work. The cam is only the trigger. The groove
is the seatbelt.
This generator upgrade completes the CYR three-device zero-fuel grid:
Device 1: CYR Tidal Pulse Tower (181.2 kW base → ~186-196 kW)
Device 2: CYR Hourglass Gravity (178 kW base → ~183-185 kW)
Device 3: CYR Pivot-Field Generator (the coupling that improves both)
FINAL GEOMETRY — ALL FIXED MAGNETS INSIDE
All fixed positioning magnets are located INSIDE the rotating wheel —
between the hub and the active magnets. NO magnets on the outer housing
wall. The wheel assembly is entirely self-contained.
+ PUSH MAGNET (inside wheel, at phi offset angular position):
North pole faces inner face of active magnet.
N→N repulsion PUSHES active magnet OUTWARD toward stator.
Result: minimum gap · maximum coupling · peak EMF captured.
− PULL MAGNET (inside wheel, at dead center angular position):
South pole faces inner face of active magnet.
S←N attraction PULLS active magnet INWARD away from stator.
Result: gap increases · F∝1/gap² · 75-90% cog eliminated.
The housing is only the stator. The entire mechanism is within the wheel.
VARIANT A — INDIVIDUAL PIVOT HOLDER
Each active magnet pivots on a pin fixed to the rotating wheel.
Pin = hinge only. Carries no load in normal operation.
CAM-LATCH MECHANISM (Addendum 17):
The cam does NOT drive the magnet. The cam trips a latch only.
Latch has two stable positions: OUT lock (extended) and IN lock (retracted).
Cam contact force = latch spring only (0.5-2N vs 100-400N magnet force).
200-800× less cam wear than direct cam drive.
SNAP-ACTION EMF: Latch holds magnet stationary (dΦ/dt = 0) until latch
releases, then field snaps holder to new position instantly.
Fast snap = maximum dΦ/dt = maximum EMF pulse.
Estimated: +15-40% peak EMF. THE LATCH IS THE EMF AMPLIFIER.
SAFETY GROOVE:
Cut inside wheel. Pin sits loosely — never touched normally.
Catches pin ONLY on failure. Groove wear = inspect fixed magnets.
Seatbelt · not steering wheel.
COG REDUCTION: F = k/gap² · gap doubled → 75% cog eliminated.
VARIANT B — RING AXIAL TRAVEL (BLDC OUTRUNNER)
The BLDC outrunner topology (drone motors, PC fans, RC motors, e-bike hubs)
uses an outer rotating ring with magnets. This variant adds controlled axial
travel of the entire ring along the shaft.
SINUSOIDAL SHAFT GROOVE:
A phi ratio sinusoidal groove is cut into the shaft surface.
Period: 360°/P per pole pair (8 pole pairs = 8 waves per revolution).
Ring pin rides in groove. As ring rotates, pin follows groove:
Groove peak (phi offset): ring shifts INWARD → max axial overlap → peak EMF
Groove trough (dead center): ring shifts OUTWARD → reduced overlap → cog reduced
The groove wave is phi ratio asymmetric (not pure sine):
Faster rise · peak at 38.17° before dead center · phi ratio fall.
NOTE:...
Alan Cyr
Andrew Ferguson
ammarbhayat28
Vipin M
Brian Stuparyk
