Hackaday.io Hackaday.io
Sign up Log in
Wheely: A Minimalist Two-Wheel Robot
Tiny ESP32-C3 Robot with DRV8833 and Python Joystick Control
stanislav-britanishskiiStanislav Britanishskii
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
0
1
1
Team (1)
  • stanislav-britanishskiiStanislav Britanishskii
Join this project's team
  • Wheely
completed project
MISC
ESP32 Robotics DRV8833 DIYRobot opensourcehardware
This project was created on 03/22/2026 and last updated 3 hours ago.
Description
A compact robot using an ESP32-C3, DRV8833 motor drivers, and two N20 motors. Power comes from a rechargeable battery with onboard charging. The bot is controlled over UDP using a Python joystick interface.
The design is lightweight and simple, though the high center of mass makes it prone to spinning in place under high power. The 3D-printed chassis was quick to assemble, with only minor adjustments needed for a misaligned motor shaft.
Software-wise, motor control was adapted from a manipulator project, while the joystick interface was generated with the help of ChatGPT. Pin selection for the ESP32-C3 required trial-and-error due to inconsistent documentation.
While the final design is rough, this unplanned little bot demonstrates the ease of getting an ESP32-C3 robot moving with DRV8833 drivers and a simple Python control interface.
Details
Components
  • 1 × esp32
  • 2 × n20 dc motor
  • 1 × drv8833 motor driver
  • 1 × battery Evaluation, Demonstration Kits, Boards and Modules / Evaluation Kits, Boards and Modules
  • 1 × battery charger
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Wheely: A Minimalist Two-Wheel Robot", please tell us the reason.
Send message
Remove Member
