Initial hardware were obtained from a Tronxy 3D Printer, namely:
- Melzi V2 control board (modified to have 5V stepper voltage on two axes)
- 2x NEMA 17 Stepper Motors
- 8mm rods for the edges (Size can be variable, but need 2x of same length for X axis)
- 2x 6mm rods for the Y axis
- 6 & 8 mm linear bearings
- Idler pulleys
Apart from this plenty of screws, bearings, and belts are needed.
The design uses CoreXY framework.
The Z axis is belted and integral to the toolhead. I chose to use a fixed max-Z endstop and BLTouch both.
The toolchanger "locking" system uses a tiny linear stepper motor found on Aliexpress, which drives a rack to turn a gear on which the key is mounted. The torque is VERY low and is making it quite challenging to have a successful coupling.
We needed low wobble and low friction, so the rest of the design has to maintain precision for this to work. Also a bit of PTFE lube worked wonders!
I attach a couple of pics of the toolhead.
The extra wires are conected to the screws and were intended to power/communicate with the tool in future. I've discovered since that the resistance is too high. Will retry or switch to pogo pins later after eliminating the coupling reliability.
I was mainly inspired by https://www.printables.com/model/137147-ratrig-vcore-3-tool-changer design on Printables, which is where I discovered the term Kinematic coupling (a constraint model for mating parts).
Prashant Sinha
wschneider
Shane Hooper
Jamie
