Project Description
What It Is and Why It Matters
AcuNode II is a distributed environmental noise monitoring system built for real outdoor deployment at an industrial research site in Alberta, Canada. Each sensor node captures A-weighted sound pressure levels through a MEMS microphone on a custom PCB, transmits measurements over LoRa radio to a central Raspberry Pi hub, which bridges the data into Home Assistant for live visualization, directional noise detection, and mobile phone alerts.
The problem it solves is straightforward: our sponsoring organization operates an active industrial and research site where construction, equipment testing, and general operations create unpredictable noise. They needed a way to know when noise levels become problematic and critically where that noise is coming from. Commercial solutions start at $5,000+ per monitoring station and don't offer multi-point directional awareness. AcuNode II does it for far cheaper.
The system was developed as a sponsored capstone project at the University of Calgary's Schulich School of Engineering. It won first place in the Electrical discipline at the 2026 Engineering Design Fair.
more details coming soon...
Omar Ahmed
Bud Bennett
Radu Motisan
Zymbit
Brenda Armour
