4S UAV Quad W/ 3D Printed Frame utilizing a Pixhawk 6C Controller
IMG_4828.movDrone Flight 1quicktime - 26.16 MB - 04/11/2026 at 15:09 |
Instead of pulling the receiver out of the water drone to reuse in the aerial build, I decided to go a different route and ordered a second FS-iA10B. That gives each craft its own dedicated receiver, which honestly makes a lot more sense long term.
At first I considered just swapping hardware between builds, but that would have turned into constant disassembly and reconfiguration every time I wanted to switch platforms. Not only is that annoying, it also introduces unnecessary wear on connectors and increases the chance of wiring mistakes.
With the FS-i6X transmitter I’m using, I already have separate model profiles set up for each vehicle, so this approach fits perfectly. Each receiver can be bound to its own profile, and I can switch between the drone and the water platform directly from the transmitter without touching the hardware.
-RR
This idea goes back some years. Back to the Erle Robotics era, when onboard compute and autonomy on small UAVs really grabbed my attention. I owned a few boards of PXFmini variety and was able to test them with what was then a brand new idea pairing them together the Raspberry Pi Zero W and Rasberry Pi 3B which in all logical theory enable endless possibilities for sensors and data. Well needless to say I was immediately captivated. Even after that path of hardware disappeared, the core goal stayed the same: build a flying system that is not just piloted, but instrumented, observable, and capable of more than manual control.
Here I am now.
-RR
I finally decided to put the quad back together today. The first test flight on this build went well and that was completely manual. After that I started using the programmed flight learning on the PC, and that is where things went sideways. I accidentally programmed it right into a tree and the whole thing became a nightmare, so it ended up sitting for a while.
Today I took a few hours and started bringing it back. I installed the motors onto new arms and reconnected part of the system. At this point I still need to pull the FlySky controller from the water drone, connect the battery, and run tests. I will probably do that tomorrow.
What I like about this build is that it does both. It can be flown manually, but it also has the hardware for autonomous flight through the Pixhawk 6C, M10 GPS, and 915 MHz telemetry. So it is not just a quad, it is a platform for both direct control and programmed behavior.
-RR
