There it is. It was hard to capture. What works is a global shutter 120fps capture with averaging.
Still a bit distorted here, but come on, it's working already :)
I'll play around a bit for beeing able to elaborate and improve on that.
A project log for Mechanical Television - 1920s parts
Building a mechanical television with parts only from the 1920s. Focusing on simplicity.
Bravo.
Thanks. There will be a demo, but I still need to work on the display code a bit.
I'll post the MCU code of the video generator as soon as it's complete.
It's very easy to use, images are streamed via FTDI cable.
Looking forward to the video demo!
Knowing nothing of "crater bulbs" I searched a bit. I'm lazy and didn't note sources, but the earliest mention I found was 1931 which is a little after your target period, but it seems that doesn't matter because the intended function of craters was to provide a bright point source for mechanically scanned optical projection -- and that isn't what you're doing. If correct, you wouldn't need a crater bulb specifically just any neon. In the 20s there were "flat plate" neon bulbs that lit up a flat square. Used in and presumably made specifically for pre-crater mechanical TV. Seems like that would be the ideal for your setup. Fact check any of that before believing. Maybe you've read all of that already.
