Spider Subtitler
Real-time speech-to-subtitle tool powered by whisper.cpp. Captures microphone audio in short chunks, transcribes and translates it (Japanese → English by default), and displays live subtitles — either overlaid on a video feed (Linux/GStreamer) or in an Electron GUI window (macOS/Linux).
How it works
id_subtitle_deamon.py— core Python daemon; records audio chunks, runs whisper.cpp for translation, and emits subtitleselectron-subtitle-app/— optional Electron GUI that wraps the daemon with a config panel and floating subtitle window
Prerequisites
All platforms
- whisper.cpp — build from source and note the path to the binary and a model file.
git clone https://github.com/ggerganov/whisper.cpp cd whisper.cpp cmake -B build && cmake --build build --config Release bash models/download-ggml-model.sh small # or base, medium, large
- Python 3.9+
Installation
macOS
# Audio capture and (optional) GStreamer overlay brew install ffmpeg pygobject3 gobject-introspection gst-plugins-base gstreamer # Python dependencies pip3 install SpeechRecognition PyAudio PyGObject
Linux (Debian / Ubuntu / Raspberry Pi)
# Audio capture (arecord) and GStreamer overlay sudo apt-get install -y \ alsa-utils \ python3-gi \ gir1.2-gstreamer-1.0 \ gstreamer1.0-tools \ gstreamer1.0-plugins-base \ gstreamer1.0-plugins-good # Python dependencies pip3 install SpeechRecognition PyAudio
Electron GUI (optional, all platforms)
Requires Node.js 18+.
cd electron-subtitle-app npm install
Running
Command-line daemon
python3 id_subtitle_deamon.py \ --whisper-bin /path/to/whisper.cpp/build/bin/whisper-cli \ --model /path/to/whisper.cpp/models/ggml-small.bin \ --source-language ja # source language (ja = Japanese, auto = auto-detect) --no-overlay # omit to use GStreamer video overlay (Linux)
Key environment variables (override defaults):
| Variable | Default (Linux) | Default (macOS) |
AUDIO_DEVICE | plughw:1,0 | :0 |
VIDEO_DEVICE | /dev/usb001 | — |
WHISPER_BIN | /home/pi/whisper.cpp/main | — |
MODEL_PATH | /home/pi/whisper.cpp/models/ggml-small.bin | — |
MIN_AUDIO_RMS | 250 | 250 |
Electron GUI
cd electron-subtitle-app npm start
Configure the whisper binary path, model path, audio device, and language from the settings panel in the app.
One-shot translation (testing)
python3 id_subtitle_deamon.py \ --test-translate /path/to/audio.wav \ --whisper-bin /path/to/whisper-cli \ --model /path/to/ggml-small.bin
Notes
- On macOS, PyGObject/GStreamer is optional; the daemon falls back to
--no-overlaymode automatically if not installed. - Adjust
--chunk-seconds(default:2) to tune latency vs. accuracy. - Set
MIN_AUDIO_RMSlower to pick up quieter audio, or higher to reduce false triggers.
TheCatwoman
ssla-couk
voidrane Splicer
Roni Bandini
mcgutschy
