GitHub
A project log for YARRM - 7-DOF Low-Cost Robot Arm
Yet Another Robot aRM - where I develop a low-cost compliant robot arm with a 1meter reach, 1KG payload.
jonathan-lussierJonathan Lussier • 08/06/2014 at 23:01•1 Comment
In order to get a better idea of the mechanisms involved, I ordered and assembled a MeArm.  I must say, for the price it's unbelievable! Here are a couple of photos.
There are a few improvements I'd make.  One, I wouldn't try supporting the entire mass of the arm a tiny 9g servo.  I would try to support it on a bearing plate, or thrust washer or something similar.  It can even be a piece of plastic.  Two, actually there is no two!  It works well!
In order to start designing mine, I have begun to use the above 2D-lasercut parts as a "baseline" for my own arm.  I used to use Solidworks but now I'm trying to keep it all open-source including the design.  Thus, OpenSCAD.  I have posted the beginning of my SCAD code here:
https://github.com/jonnycowboy/armGen/blob/master/arm.scad
which will let you parametrically design any of the support arms above, in 2D.  You can then export a DXF for cutting directly.
Jonathan Lussier wrote 03/14/2016 at 15:37 • point
Please disregard above github link and use the link in the main project page instead.
