Make LCD12864 3D Printer Boot Screen.
Basically:
1: Make an image 128 x 64 pixels. Two colours and saved as a .bmp file
2: Use LCDAssistant to create the Hex Byte text type file.
3: Copy and Paste the Hex Byte data from LCDAssistant text type file in to _Bootscreen.h file.
4 : Modify _Bootscreen.h file other settings to allow for the new Hex Byte data and image size.
5: Modify the Configuration.h file.
6: Upload and Flash the modified Marlin version 1.01.1 RC8 firmware as normal.
View all instructions
Stefan Lochbrunner
David Goodman
Brian
jonathanscottjames
Yes, delete it Cancel
You are about to report the project "Make a LCD12864 Boot Screen.", please tell us the reason.
