1Step 1
Basically:
1: Make an image 128 x 64 pixels. Two colours and saved as a .bmp file
2: Use LCDAssistant to create the Hex Byte text type file.
3: Copy and Paste the Hex Byte data from LCDAssistant text type file in to _Bootscreen.h file.
4 : Modify _Bootscreen.h file other settings to allow for the new Hex Byte data and image size.
5: Modify the Configuration.h file.
6: Upload and Flash the modified Marlin version 1.01.1 RC8 firmware as normal.
