Building a BLE Sensor Scanner with Nim and BleuIO
create a local tool that reads real-time air quality data without needing cloud connectivity.
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
In this project, we build a lightweight desktop utility that connects to a BleuIO dongle and continuously scans for BLE advertisement data. When a compatible HibouAir device is detected, the application decodes the raw hex payload and prints meaningful values such as temperature, humidity, pressure, CO2, and particulate matter levels.
This is not a heavy application or a full dashboard. It is intentionally simple. The idea is to give developers a clean starting point to understand how BLE data flows from a device to a readable format.
Full details of the project
https://www.bleuio.com/blog/building-a-ble-sensor-scanner-with-nim-and-bleuio/
