Some of the item included in this exploration:
Moun River II
- My first try at using WCH's latest update to their IDE. It seems to be less complex. The latest version is 2.40 and may be downloaded at www.mounriver.com/download. If you are using Linux don't forget to download the Toolchain which is also at rev. 2.40, available on the same page.
This project is based on the FreeRTOS example given on the WCH github.
- Running the SYSclock at maximum.
This is easily accomplished by commenting/uncommenting the appropriate lines in the system_ch32v20x.c file - I found line 27 to be the magic to get my 203 running at it's max 144 MHz. I rewrote a couple of lines a the beginning of main() to make the Clock and MCU information a little more meaningful.
CanHobby.ca
Hulk
Bikash Narayan Panda
anfractuosity
Onion.io
