Assembled ADC Breakout Board
A project log for 2 Channel USB DAQ
Where I prototype a device that digitizes two analog signals, and streams the captured samples over USB.
paul-horsfallPaul Horsfall 05/06/2026 at 15:450 Comments
Here's a picture of my first attempt at assembling one of my ADC breakout boards:
I used the hotplate method for the surface mount parts, and then hand soldered the through hole parts and SMA connectors with an iron.
This instance is populated with an AD9204 for the ADC, an 8 MHz crystal oscillator for the clock, and a pair of ADA4940 amplifiers configured for a gain of two and 50 ohm input impedance.
I've already performed a few basic checks to determine whether the board is working as expected:
So far so good. The next step is to attempt to read the data coming from the ADC.
