#include <stdlib.h>
#include <unistd.h>
#include <stdio.h>
#include <fcntl.h>
#include <linux/fb.h>
#include <sys/mman.h>
#include <sys/ioctl.h>
#include <string.h>
#include <fstream>
using namespace std;
unsigned int BinToNum(char* b, int bytes)
unsigned int tmpx = 0;
unsigned int pw = 1;
for (int i = 0; i < bytes; i++)
tmpx += ((unsigned char)b[i] * pw);
pw = pw * 256;
return tmpx;
int width = 320;
int height = 240;
int ColorBits = 16;
int size = 0;
unsigned short int* matrix;
char* fbp = 0;
int x = 0, y = 0;
long int location = 0;
int fbfd = 0;
struct fb_var_screeninfo vinfo;
struct fb_fix_screeninfo finfo;
long int screensize = 0;
int Open(const char* path)
int pad = 0;
unsigned int sof = 0;
unsigned int tx = 0;
char tmp[4] = { 0, 0, 0, 0 };
fstream file;
file.open(path, ios::in);
if (file.fail())
width = height = ColorBits = size = 0;
return -1;
else
printf("The Filesizen");
file.seekg(0, file.end);
size = file.tellg();
printf("The Filematrixn");
matrix = new (unsigned short int[size / 2]);
sof = 0;
int counter = 0;
while (sof < size)
file.seekg(sof, ios::beg);
file.read(tmp, (int)(ColorBits / 8));
tx = BinToNum(tmp, (int)(ColorBits / 8));
matrix[counter] = tx;
sof += (int)(ColorBits / 8);
counter++;
file.close();
return 1;
int blockcpfb(int source_x, int source_y, int width, int height, int dest_x, int dest_y)
for (int y = 0; y < height; y++)
for (int x = 0; x < width; x++)
location = (source_x + x) * (vinfo.bits_per_pixel / 8) + (source_y + y) * 640;
unsigned short int t = *((unsigned short int*)(fbp + location));
location = (dest_x + x) * (vinfo.bits_per_pixel / 8) + (dest_y + y) * 640;
*((unsigned short int*)(fbp + location)) = t;
int blockcp(int start, int width, int height, int dest_x, int dest_y)
unsigned short int t = matrix[(y * width) + start + x];
int blockcpclipping(int start, int width, int height, int dest_x, int dest_y, int clipx, int clipy,
int clipwidth, int clipheight)
if (x > clipx && y > clipy && x < clipx + clipwidth && y < clipy + clipheight)
int main()
fbfd = open("/dev/fb1", O_RDWR);
if (fbfd == -1)
perror("Error: cannot open framebuffer device");
exit(1);
printf("The framebuffer device was opened successfully.n");
if (ioctl(fbfd, FBIOGET_FSCREENINFO, &finfo) == -1)
perror("Error reading fixed information");
exit(2);
if (ioctl(fbfd, FBIOGET_VSCREENINFO, &vinfo) == -1)
perror("Error reading variable information");
exit(3);
printf("%dx%d, %dbppn", vinfo.xres, vinfo.yres, vinfo.bits_per_pixel);
screensize = vinfo.xres * vinfo.yres * vinfo.bits_per_pixel / 8;
fbp = (char*)mmap(0, screensize, PROT_READ | PROT_WRITE, MAP_SHARED, fbfd, 0);
if ((int)fbp == -1)
perror("Error: failed to map framebuffer device to memory");
exit(4);
printf("The framebuffer device was mapped to memory successfully.n");
x = 320;
y = 240;
if (Open("font.bin") == 1)
string s = " Guns n Roses ";
int z = 0;
for (int c = 0; c <= ((int)s.length() - 4); c++)
string tmp = s.substr(c, 4);
string::iterator i;
for (i = tmp.begin(); i != tmp.end(); i++)
blockcp((8330 * (((int)*i) - 32)), 70, 119, 40 + z * 70, 0);
z++;
int charspalte = 1;
int mychar = 0;
z = 70;
char tmp = s.at(mychar);
while (1)
blockcpfb(1, 0, 319, 119, 0, 0);
, ondoing, never Finish
if (z == 70)
blockcp((8330 * (((int)tmp) - 32)), 70, 119, 320 - 70, 0);
z = 0;
mychar++;
charspalte = 1;
if (mychar == s.length())
mychar = 0;
else
charspalte++;
z++;
close(fbfd);
return 0;
