Log #4: Anatomy of a radiator – from raw aluminum to the finished product.
A project log for USBridge-KVM 2.0
Ultra-Low Latency IP-KVM with AI-Ready BIOS-in-Terminal, Drive Emulation, and Immutable Snapshots.
amirAmir 05/25/2026 at 12:500 Comments
I'd like to share behind-the-scenes details about the colossal amount of manual R&D and physical iterations that went into perfecting just one component of the USBridge-KVM 2.0.
I started with standard, off-the-shelf aluminum fin extrusions and solid copper blocks. Since I'm not a professional lathe operator, I had to manually cut, file, and fit the aluminum extrusions. Every millimeter mattered to ensure the active turbine fan would fit perfectly in the case and air would be efficiently exhausted from the sides.
Perfectly aligning the custom cooler mounts and mounting standoffs took several tries. A fraction of a millimeter off meant improper contact with the SoC or misalignment of the assembly inside the SLS 3D-printed case.
Testing various thin-layer paints ensured a clean and professional-looking surface without isolating the aluminum or causing bubbling under constant thermal loads.
James Dyson famously created 5,127 prototypes before completing his first vacuum cleaner. While I'm nowhere near that legendary number, my approach to hardware development remains the same: every component, no matter how passive it may seem, requires maximum effort to achieve the perfect balance of form, function, and reliability.
