Modern ecosystem for secure firmware updates in embedded systems
The project consists of three integrated applications forming a complete secure firmware distribution pipeline for embedded devices.
The ecosystem was designed to provide a lightweight and practical secure boot solution for resource-constrained microcontrollers.
One of the primary goals was minimizing bootloader size while still providing a reasonable level of firmware protection.
The security model was intentionally simplified to keep the implementation lightweight and portable even for small MCU platforms.
The ecosystem was designed with focus on:
🧱 Ecosystem Architecture
│   Firmware BIN  │
│   EncryptBIN    │
│ Encrypt package │
│  SecureLoader   │
│ Upload utility  │
         │ UART / Serial
│SECURE_BOOTLOADER│
│ Secure boot     │
│   Application   │
🔐 SECURE_BOOTLOADER
Lightweight and modular MCU bootloader
The primary goal of the project was to create the smallest possible bootloader that still provides a reasonable level of firmware protection while maintaining minimal Flash/RAM footprint and simple integration.
SECURE_BOOTLOADER is responsible for secure firmware reception and application startup in embedded systems.
The project was designed with strong modularity in mind — hardware-specific code is fully separated from the bootloader core logic, making it easy to port the project to new MCU families.
The project intentionally uses a relatively simple security model based on AES-128 encryption and firmware validation, allowing it to run even on resource-constrained microcontrollers.
For commercial products or high-security environments it is recommended to additionally consider:
✨ Key features
🧱 Currently implemented platforms
The repository also includes ready-to-use templates for adding new MCU families and hardware configurations.
Thanks to the separated hardware abstraction layer, porting the bootloader to new targets mainly requires implementing the low-level hardware layer.
🚀 SecureLoader
Crossplatform firmware upload utility
SecureLoader handles communication with the bootloader and transfers firmware packages to the target device.
The application was designed both for end users and production environments.
✨ Key features
🤖 Automation-first approach
CLI mode allows seamless integration with:
GUI mode provides a convenient interface for manual firmware updates during development and maintenance.
🔑 EncryptBIN
Secure firmware package generator
EncryptBIN is responsible for generating encrypted firmware packages ready for secure distribution.
It provides the security layer between compiled firmware binaries and target devices.
✨ Key features
🤖 Automation support
CLI mode allows easy integration with:
GUI mode simplifies firmware package generation during development.
⚙️ Ecosystem Workflow
Firmware BIN
EncryptBIN
(encryption + package)
SecureLoader
(upload over UART)
SECURE_BOOTLOADER
(validation + flashing)
Application Start
🧠 Project Goals
🔒 Security First
Firmware is encrypted before distribution.
🤖 Automation Ready
CLI support enables seamless CI/CD and manufacturing integration.
🌍 Crossplatform
The entire ecosystem is designed to work across multiple platforms.
🧩 Modular Architecture
Separated hardware abstraction layer simplifies development and maintenance.
⚡ Lightweight Embedded Design
The bootloader is optimized for resource-constrained MCUs.
🛠️ Technologies
Embedded
Security
Desktop
🎯 Use Cases
💡 Main Advantages
✅ Complete secure firmware ecosystem
✅ AES-128 firmware encryption
✅ GUI + CLI applications
✅ Full automation support
✅ Crossplatform desktop tools
✅ Crossplatform bootloader architecture
✅ Hardware abstraction layer
✅ Hardware CRC support
✅ Lightweight embedded design
✅ Easy MCU family porting
