Modern ecosystem for secure firmware updates in embedded systems
The project consists of three integrated applications forming a complete secure firmware distribution pipeline for embedded devices.
The ecosystem was designed to provide a lightweight and practical secure boot solution for resource-constrained microcontrollers.
One of the primary goals was minimizing bootloader size while still providing a reasonable level of firmware protection.
The security model was intentionally simplified to keep the implementation lightweight and portable even for small MCU platforms.
The ecosystem was designed with focus on:
- 🔒 firmware protection
- ⚡ fast firmware updates
- 🧩 modular architecture
- 🤖 automation workflows
- 🌍 full crossplatform support
- 🏭 easy production and CI/CD integration
🧱 Ecosystem Architecture
┌─────────────────┐ │ Firmware BIN │ └────────┬────────┘ │ ▼ ┌─────────────────┐ │ EncryptBIN │ │ Encrypt package │ └────────┬────────┘ │ ▼ ┌─────────────────┐ │ SecureLoader │ │ Upload utility │ └────────┬────────┘ │ UART / Serial ▼ ┌─────────────────┐ │SECURE_BOOTLOADER│ │ Secure boot │ └────────┬────────┘ │ ▼ ┌─────────────────┐ │ Application │ └─────────────────┘
🔐 SECURE_BOOTLOADER
Lightweight and modular MCU bootloader
The primary goal of the project was to create the smallest possible bootloader that still provides a reasonable level of firmware protection while maintaining minimal Flash/RAM footprint and simple integration.
SECURE_BOOTLOADER is responsible for secure firmware reception and application startup in embedded systems.
The project was designed with strong modularity in mind — hardware-specific code is fully separated from the bootloader core logic, making it easy to port the project to new MCU families.
The project intentionally uses a relatively simple security model based on AES-128 encryption and firmware validation, allowing it to run even on resource-constrained microcontrollers.
For commercial products or high-security environments it is recommended to additionally consider:
- firmware signing
- stronger authentication mechanisms
- secure key storage
- more advanced cryptographic algorithms
- full secure boot chain implementation
✨ Key features
- 🔐 AES-128 firmware encryption
- ⚡ hardware CRC support when MCU provides CRC peripheral
- 🧩 separated hardware abstraction layer
- 🌍 crossplatform architecture
- 🚀 fast startup
- 📦 UART firmware updates
- 🛡️ firmware validation
- ⚙️ multiple hardware configurations support
- 🧠 optimized Flash and RAM usage
🧱 Currently implemented platforms
- STM32G07x
- STM32G474
- ATmega328
The repository also includes ready-to-use templates for adding new MCU families and hardware configurations.
Thanks to the separated hardware abstraction layer, porting the bootloader to new targets mainly requires implementing the low-level hardware layer.
🚀 SecureLoader
Crossplatform firmware upload utility
SecureLoader handles communication with the bootloader and transfers firmware packages to the target device.
The application was designed both for end users and production environments.
✨ Key features
- 🖥️ GUI + CLI
- 🤖 full automation through CLI
- 📡 UART/Serial communication
- 📦 encrypted firmware package support
- ⚡ fast data transfer
- 🧾 update process logging
- 🔍 automatic device detection
🤖 Automation-first approach
CLI mode allows seamless integration with:
- CI/CD pipelines
- production lines
- automated testing systems
- device provisioning workflows
- deployment scripts
GUI mode provides a convenient interface for manual firmware updates during development and maintenance.
🔑 EncryptBIN
Secure firmware package generator
EncryptBIN is responsible for generating encrypted...
niwciu
Florian Baumgartner
Matthias Schulz
ON3 Paul Krause
MIG
