Generating PCB production files with kicad-cli
A project log for Vertical LED digit display boards
Hang on, is that a display on your wall?
ken-yapKen Yap 05/17/2026 at 23:312 Comments
For a couple of versions now, KiCad has had a command line tool for generating production outputs. How does this improve the workflow? For one thing, instead of specifying outputs and options, and generating files from the GUI, you do it from the command line. This allows you to use scripts which gives reproducible results, free from having to ensure that all the right boxes have been filled in or ticked in the GUI. For this project i have used a Makefile. Here it is:
PROJECT=6segment
VERSION=7
SCHFILE=$(PROJECT).kicad_sch
PCBFILE=$(PROJECT).kicad_pcb
LAYERS=F.Cu,B.Cu,F.Mask,B.Mask,F.Silkscreen,B.Silkscreen,Edge.Cuts
OUTPUTDIR=output
BOMFIELDS=$${QUANTITY},Reference,Value,Footprint,Description,Type,Manufacturer,MPN
BOMLABELS=Quantity,Designator,Value,Package,Description,Type,Manufacturer,MPN
BOMFILE=$(OUTPUTDIR)/$(PROJECT)-bom.csv
POSFILE=$(OUTPUTDIR)/$(PROJECT)-pos.csv
ZIPDIR=/var/tmp/Tmp
ZIP=$(ZIPDIR)/$(PROJECT)-v$(VERSION).zip
all:    gerbers bom pos zip
$(OUTPUTDIR):
        mkdir -p $(OUTPUTDIR)
gerbers:        $(PCBFILE) $(OUTPUTDIR)
        kicad-cli pcb export gerbers -o $(OUTPUTDIR) --no-protel-ext -l $(LAYERS) $<
        kicad-cli pcb export drill -o $(OUTPUTDIR) --excellon-separate-th $<
        kicad-cli pcb export ipcd356 -o $(OUTPUTDIR)/$(PROJECT)-netlist.ipc $<
bom:    $(SCHFILE) $(OUTPUTDIR)
        kicad-cli sch export bom -o $(BOMFILE) --fields '$(BOMFIELDS)' --labels '$(BOMLABELS)' --group-by Value --ref-range-delimiter '' $<
pos:    $(PCBFILE) $(OUTPUTDIR)
        kicad-cli pcb export pos -o $(POSFILE) --format csv --units mm --side back --use-drill-file-origin --smd-only $<
        sed -i -e '1s/Ref,Val,Package,PosX,PosY,Rot,Side/Designator,Value,Footprint,Mid X,Mid Y,Rotation,TB/' -e 's/bottom/B/' $(POSFILE)
zip:    gerbers
        rm -f $(ZIP)
        zip -jo $(ZIP) $(OUTPUTDIR)/*.{gbr,drl,ipc}
For the gerbers rule we generate the layers specified, then generate the two drill files, and finally a IPC-D-356 netlist to help the fabricator test the boards. A zip rule combines them into a file ready to upload.
The other two rules generate the Bill of Materials (BOM) and Component Placement List (CPL, also called POS) files containing assembly information. I looked at PCBWay's instructions for BOM and POS file format, and tried to follow it as close as possible.
For the BOM, the order of the labels and content of the columns is specified with the --labels and --fields arguments to the kicad-cli sch export bom command. ${QUANTITY} is a meta-field, it will be replaced with the number of items in that row. The $$ is to get a single $ past Makefile escaping rules. Here's what the BOM contains:
"Quantity","Designator","Value","Package","Description","Type","Manufacturer","MPN"
"1","C11","10u","Capacitor_SMD:C_0805_2012Metric","Unpolarized capacitor, small symbol","SMD","",""
"1","C12","100n","Capacitor_SMD:C_0805_2012Metric","Unpolarized capacitor, small symbol","SMD","",""
"13","Q21,Q22,Q23,Q24,Q25,Q26,Q31,Q32,Q33,Q34,Q35,Q36,Q38","SS8050","Package_TO_SOT_SMD:SOT-23","General Purpose NPN Transistor, 1.5A Ic, 25V Vce, SOT-23","SMD","",""
"2","R11,R12","47k","Resistor_SMD:R_0805_2012Metric","Resistor, small symbol","SMD","",""
"26","R21,R22,R23,R24,R25,R26,R31,R32,R33,R34,R35,R36,R38,R221,R222,R223,R224,R225,R226,R321,R322,R323,R324,R325,R326,R328","1k","Resistor_SMD:R_0805_2012Metric","Resistor, small symbol","SMD","",""
"2","U1,U2","74HC595D","Package_SO:SOIC-16_3.9x9.9mm_P1.27mm","8-bit serial in/out Shift Register 3-State Outputs","SMD","",""
The Type field is an additional attribute that was added to each symbol to be assembled and is always SMD, as the assembly of the THT LEDs and the Dupont pin header will be done by me. The Manufacturer and MPN fields were left blank (actually kicad-cli will generate blank content for non-existent attributes) so that PCBWay can do the sourcing of the parts. Like nearly all other PCBA companies in China, PCBWay is not a stockist and will look on the market for the parts you specified. A couple of the tickboxes in the order form asks if you are willing to use equivalent or made in China parts. I have absolutely no issues with equivalent parts or made in China parts, as this project uses commodity parts, and they are probably made in China anyway.
I worried a bit about the order of the columns and tried to follow the PCBWay guidelines. In the end it wasn't a problem, as they understood what I wanted and anyway the confirmation CSV came back in a different order. The only queries were whether I accepted the manufacturer of the SS8050 jelly-bean transistors, and changing the 74HC595D to 74HC595DR because SOIC by itself is not sufficiently specific and you must specify the correct package for the appropriate dimensions and pin pitch.
(Here I want to put in a plug for the SS8050 which seems to have originated with Fairchild decades ago in the TO-92 package. I think it's a superior jelly-bean transistor to the commonly used MMBT3904 as it has excellent gain characteristics across the range of current and high current capacity. One drawback is the relatively low Vceo of 25V.)
Now the POS file specifies the positions of the centroid of the SMD parts for the pick and place machine. Unfortunately kicad-cli doesn't allow a custom order for the columns. However I had a sed command to change the labels on the columns to close to the PCBWay example and also change the assembly side of "bottom" to B.
"C11","10u","C_0805_2012Metric",71.120000,15.240000,0.000000,B
"C12","100n","C_0805_2012Metric",43.180000,50.800000,-90.000000,B
"Q21","SS8050","SOT-23",33.020000,76.200000,90.000000,B
"Q22","SS8050","SOT-23",22.860000,66.040000,-90.000000,B
"Q23","SS8050","SOT-23",38.100000,33.020000,-90.000000,B
"Q24","SS8050","SOT-23",22.860000,33.020000,-90.000000,B
"Q25","SS8050","SOT-23",12.700000,50.800000,-90.000000,B
"Q26","SS8050","SOT-23",5.080000,76.200000,90.000000,B
"Q31","SS8050","SOT-23",86.360000,83.820000,90.000000,B
"Q32","SS8050","SOT-23",86.360000,60.960000,90.000000,B
"Q33","SS8050","SOT-23",76.200000,33.020000,-90.000000,B
"Q34","SS8050","SOT-23",67.630000,33.020000,90.000000,B
"Q35","SS8050","SOT-23",63.500000,38.100000,-90.000000,B
"Q36","SS8050","SOT-23",63.500000,76.200000,90.000000,B
"Q38","SS8050","SOT-23",91.440000,38.100000,-90.000000,B
"R11","47k","R_0805_2012Metric",25.400000,20.320000,180.000000,B
"R12","47k","R_0805_2012Metric",25.400000,15.240000,180.000000,B
"R21","1k","R_0805_2012Metric",30.480000,71.120000,90.000000,B
"R22","1k","R_0805_2012Metric",20.320000,71.120000,-90.000000,B
"R23","1k","R_0805_2012Metric",35.560000,43.180000,-90.000000,B
"R24","1k","R_0805_2012Metric",27.940000,43.180000,-90.000000,B
"R25","1k","R_0805_2012Metric",12.700000,58.420000,-90.000000,B
"R26","1k","R_0805_2012Metric",20.320000,76.200000,90.000000,B
"R31","1k","R_0805_2012Metric",86.360000,76.200000,90.000000,B
"R32","1k","R_0805_2012Metric",88.900000,53.340000,90.000000,B
"R33","1k","R_0805_2012Metric",71.120000,43.180000,-90.000000,B
"R34","1k","R_0805_2012Metric",71.120000,38.100000,-90.000000,B
"R35","1k","R_0805_2012Metric",66.040000,43.180000,-90.000000,B
"R36","1k","R_0805_2012Metric",66.040000,71.120000,90.000000,B
"R38","1k","R_0805_2012Metric",88.900000,43.180000,90.000000,B
"R221","1k","R_0805_2012Metric",27.940000,76.200000,-90.000000,B
"R222","1k","R_0805_2012Metric",27.940000,66.040000,90.000000,B
"R223","1k","R_0805_2012Metric",38.100000,38.100000,90.000000,B
"R224","1k","R_0805_2012Metric",30.480000,33.020000,-90.000000,B
"R225","1k","R_0805_2012Metric",20.320000,50.800000,-90.000000,B
"R226","1k","R_0805_2012Metric",5.080000,71.120000,-90.000000,B
"R321","1k","R_0805_2012Metric",72.390000,76.200000,-90.000000,B
"R322","1k","R_0805_2012Metric",81.280000,53.340000,-90.000000,B
"R323","1k","R_0805_2012Metric",76.200000,43.180000,90.000000,B
"R324","1k","R_0805_2012Metric",71.120000,20.320000,0.000000,B
"R325","1k","R_0805_2012Metric",60.960000,33.020000,-90.000000,B
"R326","1k","R_0805_2012Metric",60.960000,71.120000,-90.000000,B
"R328","1k","R_0805_2012Metric",93.980000,43.180000,90.000000,B
"U1","74HC595D","SOIC-16_3.9x9.9mm_P1.27mm",40.640000,60.325000,0.000000,B
"U2","74HC595D","SOIC-16_3.9x9.9mm_P1.27mm",53.340000,51.435000,180.000000,B
Again PCBWay had no problems understanding what I wanted. So now to say yes to the two changes and get approval for the sponsorship.
Paul McClay wrote 05/18/2026 at 16:48 point
I don't know how well this generalizes among PCBA & EDA options, because I haven't done any of this for real yet myself, but thanks for posting one great worked example!
Ken Yap wrote 05/18/2026 at 22:30 point
Another method is to use the KiCad external plugin that the PCB factory has provided for submitting jobs. PCBWay has one.
