Communicator Badge Full RGB Keyboard
RGB-LED keyboard mod for the 2025 Supercon/2026 Hackaday Europe badge
The 2025/2026 Hackaday badge was modded with a custom front PCB containing 73 addressable LED (one per key) and a custom resin-printed keyboard with semi-transparent keys. The front-PCB and the keyboard are compatible with the original stackup and just replace the original components. The addressable LEDs are connected to a GPIO from the badge CPU and controlled via Micropython.
kicad_communicator_pcb-front_rgb.zip
KiCad project
x-zip-compressed - 394.78 kB - 05/19/2026 at 06:34
Download
front_pcb.zip
Gerber data
x-zip-compressed - 3.17 MB - 05/18/2026 at 16:33
Download
key_alpha.stl
Standard Tesselated Geometry - 4.20 MB - 05/18/2026 at 16:24
Download
numkey.stl
number keys
Standard Tesselated Geometry - 2.01 MB - 05/18/2026 at 16:23
Download
func.stl
function keys
Standard Tesselated Geometry - 581.72 kB - 05/18/2026 at 16:23
Download
View all 6 files
  • 73 × SK6805-EC4004 (LCSC C5440838) 0.4 mm side emitting LED
  • Keyboard
    makeTVee • 05/26/2026 at 18:37 • 0 comments
    The keyboard design was taken from the original Github repo and slightly modified for a good fit (after ordering the PCBs) and with a small border at the bottom to hold tight in the flexible frame. Files are available as STL.
    The keys were resin-printed with a mix of white and transparent resin (approx. 80% transparent, 20% white). A paint marker pen was used to mark the letters in black.
     After drying for 1-2 minutes, the top surface was cleaned with IPA and the letter was clearly visible.
    It's not perfect, but in reality the imperfections are not visible, especially when the lights are on.
    The keys are hold together with a thin flexible TPU frame (FDM printed with 2 layers, 0.3mm).
  • Side emitting LEDs
    makeTVee • 05/19/2026 at 18:01 • 0 comments
    The thinnest available side-emitting addressable LEDs (0.4mm) are used to light up every single key. They are hand-placed directly at the edge of every key opening.
View all 2 project logs
damiano wrote 05/22/2026 at 15:43 • point
Fantastic !
this is so coool !
Bravo :))
Brett Walach wrote 05/20/2026 at 16:03 • point
Yo, this is sick!  Great job!
