Wireless Distance Monitoring with Arduino and XBee
Arduino Uno and TF-Luna LiDAR based wireless distance monitoring system using Xebee S2C for real-time remote sensing.
0 followers
This project demonstrates a wireless distance monitoring system built using an Arduino Uno, a TF-Luna LiDAR sensor, and XBee S2C wireless modules. The TF-Luna continuously measures the distance to nearby objects and communicates the data to the Arduino via the I2C interface. After processing the sensor readings, the Arduino transmits the distance information wirelessly through an XBee S2C module.
On the receiving end, a second XBee module connected to a computer or microcontroller receives the transmitted data for real-time display and logging. The between sensing unit and monitoring unit reduce the need of wired cable and make this system wireless remote monitoring, object detection. It is better for educational projects and IoT projects. This project enables monitoring the distance between two objects.
Overview
Wireless distance monitoring is useful in many applications where direct wired connections are difficult or impractical. This project demonstrates a simple and reliable wireless distance monitoring system using an Arduino Uno, a TF-Luna LiDAR sensor, and XBee S2C wireless modules.
The TF-Luna LiDAR sensor continuously measures the distance to an object and sends the measurement data to the Arduino Uno through the I2C communication interface. The Arduino processes the received distance values and transmits them wirelessly using an XBee S2C module. A second XBee module placed at the receiving end collects the transmitted data and forwards it to a computer or another microcontroller for monitoring and logging.
The system eliminates the need for long wired connections between the sensing unit and the monitoring station, making it suitable for remote sensing applications, obstacle detection systems, industrial monitoring, robotics projects, and educational demonstrations.
Features
  • Real-time distance measurement using TF-Luna LiDAR
  • Wireless data transmission using XBee S2C modules
  • Arduino Uno based implementation
  • I2C communication with the LiDAR sensor
  • Simple and low-cost architecture
  • Expandable for IoT and industrial monitoring applications
  • Reliable wireless communication without Wi-Fi dependency
Hardware Components
Component
Quantity
Arduino Uno
1
TF-Luna LiDAR Sensor
1
XBee S2C Wireless Module
2
XBee USB Adapter / Shield
1
Jumper Wires
As Required
USB Cable
1
Computer with Arduino IDE
1
System Architecture
TF-Luna LiDAR
       │ I2C
Arduino Uno
       │ Serial Communication
XBee S2C Transmitter
       │ Wireless Communication
XBee S2C Receiver
PC / Arduino Receiver
Distance Display & Logging
How It Works
  1. The TF-Luna LiDAR sensor continuously measures the distance to nearby objects.
  2. The sensor sends distance information to the Arduino Uno using the I2C interface.
  3. Arduino reads and processes the incoming sensor data.
  4. The measured distance value is converted into a readable format.
  5. The XBee S2C transmitter sends the distance data wirelessly.
  6. The receiver-side XBee module receives the transmitted information.
  7. The received distance values are displayed on a serial monitor or stored for future analysis.
Wiring Connections
TF-Luna LiDAR to Arduino Uno
TF-Luna
Arduino Uno
VCC
5V
GND
GND
SDA
A4
SCL
A5
XBee S2C to Arduino Uno
XBee
Arduino Uno
VCC
3.3V
GND
GND
TX
RX
RX
TX
Software Requirements
  • Arduino IDE
  • XBee XCTU Software
  • TF-Luna Library (if required)
  • XBee Configuration Utility
Testing Procedure
  1. Configure both XBee modules using XCTU.
  2. Upload the Arduino code.
  3. Power the transmitter unit.
  4. Place an object at different distances from the TF-Luna sensor.
  5. Observe distance values on the receiver side.
  6. Verify wireless transmission accuracy and response time.
Results
The system successfully measured distances using the TF-Luna LiDAR sensor and transmitted the data wirelessly through XBee S2C modules. Distance readings were received in near real time with stable communication between the transmitter and receiver units.
The project demonstrates that LiDAR-based sensing combined with XBee wireless communication can be used for reliable remote monitoring applications.
Applications
  • Remote Distance Monitoring
  • Obstacle Detection Systems
  • Industrial Automation
  • Warehouse Monitoring
  • Smart Agriculture
  • Robotics Navigation
  • Educational STEM Projects
  • Security and Surveillance Systems
Future...
  • 1 × Arduino Uno
  • 1 × TF-Luna LiDAR
  • 1 × Digi XBee S2C
  • 1 × Jumper wires (M-M and M-F)
  • 1 × Breadboard Electronic Components / Misc. Electronic Components
  • 1
    Step 1: Connect TF-Luna LiDAR to Arduino Uno
    Connect the TF-Luna LiDAR sensor to the Arduino Uno using the I2C interface.
  • 2
    Step 2: Connect XBee S2C Module
    Wire the XBee S2C module to the Arduino Uno for wireless communication.
  • 3
    Step 3: Configure the XBee Devices
    Configure both XBee modules using XCTU software with matching communication settings.
View all 10 instructions
