to build this you need:
  • an ultimaker original
  • 2 carbon tubes 4mm diameter length 166
  • 1 standard servo
  • 2 micro servos (Reely RE-6609276 ) conrad 2203092
  • brass tube diam 2.5 length 11 mm
  • 14 m2 bolts (various lengths
  • 7 m2 nuts
  • 3 m3 bolts 25 mm
  • some m2 and m3 washers
  • some nylon wire
  • some low friction material (teflon foil)
  • some iron wire
  • hotmelt glue
  • 3 printer with PLA filament
  • CA glue
