Graphics terminal for small computers
Draw graphics through a serial port
0 followers
This project shows how to get a Linux computer (desktop or Raspberry Pi) to serve as a graphics terminal to an 8-bit computer such as the 6502, Z80 or 6809. Commands are sent through a comms channel (RS232 or SPI) and the Linux computer renders them.
After investigating the X-Windows system and finding it would need far more resources than an 8-bit computer can provide, and not wanting to re-invent a wheel, I looked around to see if a much simpler command set already existed.
The Tektronix 4010/4014 was a graphics terminal based on CRT technology. Lines were drawn in a long-persistence phosphor, and could only be removed by erasing the whole screen at once. There was only the fixed colour of the phosphor, so there were no colour related commands.
The Tektronix 4027 used a memory array to store pixels, just like today's video technology. It added colour based commands.
XTerm (available in Linux Mint's package manager) has native, historically perfect Tektronix 4014 emulation built right in. You can switch an XTerm window into Tektronix mode using an escape sequence or by Ctrl+Right Clicking the window. It instantly maps a high-resolution canvas ((1024 x 780) virtual space) that your 8-bit microcomputer can draw on with minimal compute overhead.
xterm does not support Tektronix 4027 color commands. It is strictly limited to the monochrome Tektronix 4014 standard. If you send Tektronix 4027 specific color escape sequences (like !INK or !FILL) into xterm's Tektronix window, it will simply ignore or misinterpret them.
While xterm cannot parse Tektronix 4027 multi-color per-object commands, it does allow the host computer to change the global foreground color of the Tektronix window dynamically using standard ANSI master escape sequences.
Using Python 3 with the pygame and pyserial libraries, you can completely bypass X11 complexity on Linux Mint. Pygame acts as a lightweight wrapper over X-Windows, handling all the frustrating OS window management in the background. This approach gives you total freedom to emulate the classic Tektronix !INK, !VEC, and !GRA codes, while making it easy to add your own custom extensions (like !SPRITE or !SOUND).
I asked Google AI to write me code to demonstrate all this. And like my X-Windows exploration project, have a program sending graphics commands to draw a 3-d surface with hidden-face removal and brightness controlled by the angle of an illumination source. This is known as 'the sun vector normal'. The commands are sent through virtual communications links.
As usual, AI needed cajoling into providing what I wanted. The first attempt used an EGA/CGA font of 16 colours, which is 8 colours in light and dark. EGA and CGA were short lived standards, quickly replaced by VGA. The VGA's programmable palette has 256 entries, with a default palette that looks like this:
The program then ran with a limited number of colours and brightness, because it was difficult to translate colour and brightness onto a limited palette like this. So I asked for just a grey-scale rendering, with a minimum dark level to avoid unlit facets disappearing into the black background. Here is the result.
I feel this is a satisfactory proof of concept.
You can modify the code so that the colours specified in full 3x8-bit RGB, without VGA palette entry numbers, but the commands will be longer.
An 8-bit processor is unlikely to have a Python interpreter, so the surface-drawing code would need translating to BASIC, assembler, C, or whatever you wish. You might even modify your BASIC interpreter to output graphic commands to a serial port, or a file if you want to save them for later rendering.
3d_generator.py
Generates the commands for the graphics terminal. Written in Python, this needs to be ported to a small external computer.
x-python - 4.23 kB - 06/24/2026 at 23:03
Download
graphics_server.py
The Linux PC code that parses the incoming commands and calls the routines to execute them.
x-python - 2.89 kB - 06/24/2026 at 23:03
Download
  • Speed
    Keith6 hours ago 0 comments
    A Linux machine is likely to run the Python graphics generator, or a full emulation of an 8-bit micro, far faster than a real 8-bit computer. This makes it a great way of developing and debugging programs far faster.
    To optimise speed on a real 8-bit machine, remember that floating-point maths and trigonometry are hard work for 8-bit micros. There will be a lot of this in 3d graphics. Minimising this will be a test of your programming skills!
  • Instructions
    Install the Prerequisites
    Open your Linux Mint terminal and install socat alongside the Python libraries:
    In a bash shell:
    sudo apt update
    sudo apt install socat python3-pip
    pip3 install pygame pyserial
    sudo apt install python3-serial
    sudo apt install python3-pygame
    Open a bash shell and start the virtual communication ports
    Run this command in a dedicated terminal window. It creates two linked virtual ports (/tmp/vtty0 and /tmp/vtty1).
    socat -d -d pty,link=/tmp/vtty0,raw,echo=0 pty,link=/tmp/vtty1,raw,echo=0
    Open another bash shell and start the graphics server
    python3 graphics_server.py
    Open another bash shell and start the 3d graphics generator
    python3 3d_generator.py
View all 2 project logs
