Speed
12 hours ago • 0 commentsA Linux machine is likely to run the Python graphics generator, or a full emulation of an 8-bit micro, far faster than a real 8-bit computer. This makes it a great way of developing and debugging programs far faster.
To optimise speed on a real 8-bit machine, remember that floating-point maths and trigonometry are hard work for 8-bit micros. There will be a lot of this in 3d graphics. Minimising this will be a test of your programming skills!
Instructions
12 hours ago • 0 commentsInstall the Prerequisites
Open your Linux Mint terminal and install
socatalongside the Python libraries:In a bash shell:
sudo apt update sudo apt install socat python3-pip pip3 install pygame pyserial sudo apt install python3-serial sudo apt install python3-pygame
Open a bash shell and start the virtual communication ports
Run this command in a dedicated terminal window. It creates two linked virtual ports (
/tmp/vtty0and/tmp/vtty1).socat -d -d pty,link=/tmp/vtty0,raw,echo=0 pty,link=/tmp/vtty1,raw,echo=0
Open another bash shell and start the graphics server
python3 graphics_server.py
Open another bash shell and start the 3d graphics generator
python3 3d_generator.py
Keith
