Millions of developers use desktop Macs and Linux machines without any biometric auth. We're building a tiny wireless fingerprint key to fix that.
If you use a Mac mini, Mac Studio, or a MacBook in clamshell mode with an external keyboard, you know the pain: no Touch ID. Apple’s only solution is a $199 Magic Keyboard — and if you prefer a mechanical keyboard, you’re completely out of luck.
Linux users have it even worse. fprintd exists, but good hardware options are scarce.
The problem
Every time you:
- Unlock your screen
- Run sudo / ssh
- Approve a system dialog
- Sign a Git commit
…you type a password. Dozens of times a day.
Our solution
immurok is a tiny wireless device with a capacitive fingerprint sensor. It connects via Bluetooth LE and replaces passwords with a single touch:
- Screen unlock — touch the sensor, screen unlocks
- sudo & PAM — custom PAM module intercepts auth prompts
- SSH agent — sign commits and SSH into servers with your fingerprint
- Open source — the macOS app and PAM module are fully auditable
Security first
Your fingerprint template never leaves the device. Authentication uses ECDH P-256 key exchange and HMAC-SHA256 signed messages. There’s no cloud, no account, no telemetry — everything works offline over Bluetooth.
We’ll be sharing more technical deep-dives on the BLE protocol, PAM integration, and firmware architecture in upcoming posts. Stay tuned.
superdog
