Why desktop fingerprint authentication is still awkward on Mac and Linux
A project log for immurok - a wireless fingerprint auth key
immurok is a small wireless fingerprint authentication device for Mac and Linux desktops
superdogsuperdog an hour ago0 Comments
Touch ID is excellent when it is built into the machine or keyboard. The awkward part starts everywhere else: Mac mini, Mac Studio, closed-lid MacBooks, external keyboards, Linux desktops, and terminal-heavy workflows.
immurok is my attempt to build a small wireless fingerprint key for those setups.
It is not meant to be “Apple Touch ID, but external.” Touch ID is Apple’s own secure platform, deeply fused into the Secure Enclave and the OS. immurok is something more modest and more honest about its scope: a local-first desktop authentication device with clear limits.
immurok desktop authentication architecture
Where built-in fingerprint auth runs out
If you use a laptop with the sensor under your thumb, none of this is your problem. But a lot of desktop computing doesn’t look like that:
The common thread is that biometric auth is welded to specific hardware. The moment your setup steps outside that hardware, you’re back to typing passwords.
What immurok actually is
A small wireless key with a capacitive fingerprint sensor that pairs to your computer over Bluetooth LE. Concretely, its scope is:
It is deliberately a single-purpose device. No screen, no account, no app store — a key that proves a fingerprint touch happened, and lets your OS act on it.
immurok features overview
The distinction that matters: PAM, not a typed password
Here is the part I most want to be clear about, because it’s the easiest thing to get wrong when you build something like this.
For sudo and system authentication, immurok is not just typing a stored password for you. A lot of “fingerprint unlock” gadgets are really just a biometric trigger wired to a password autotyper: they keep your password somewhere, and when you touch the sensor they replay it into the prompt. That works, but it means your password is sitting in storage, and anything that can see the keystrokes sees your password.
On Linux, immurok integrates through PAM — the same authentication framework sudo, login, and polkit already use. When you run sudo, the PAM stack asks immurok’s module, the module checks with your paired device over an authenticated channel, you touch the sensor, and PAM gets back a real success/failure result. There’s no stored password being replayed — the authentication decision flows through the OS’s own auth pipeline, the way a fingerprint should.
On macOS the picture is split, and it’s worth being precise:
That asymmetry isn’t a limitation we’re hiding; it’s a property of the platforms. Linux exposes a clean biometric path through PAM end to end. macOS exposes it for some flows and walls off the lock screen. immurok uses the real path wherever the OS offers one.
immurok key with its leather case
Honest about the limits
immurok is local-first and deliberately narrow. It does not replace the Secure Enclave, it does not integrate with App Store purchases or LAContext the way Apple’s own biometrics do, and it does not pretend to be Touch ID. It is a wireless fingerprint key for the desktop setups Apple and the Linux ecosystem left without a good option — with the matching done on the device, the secrets kept off your disk, and the security model written up in full so you don’t have to take any of this on faith.
If your desk is one of the awkward setups above, that’s exactly who I built it for. The macOS app, PAM module, and Linux app are on GitHub; if you want to try the device before launch, join the waitlist.
