1Prepare the Components
Collect all required hardware including the ESP32 development board, RC522 RFID reader, RFID cards, LEDs, buzzer, and connecting wires.
2Connect the RFID Reader
Wire the RC522 module to the ESP32 using the SPI interface.
Typical connections include:
- SDA
- SCK
- MOSI
- MISO
- RST
- 3.3V
- GND
Double-check all wiring before powering the board.
3Add Status Indicators
Connect LEDs to indicate:
- Power ON
- Successful Scan
- Invalid Card
Optionally connect a buzzer for audible confirmation.
4Configure the ESP32
Install the required Arduino libraries and configure:
- Wi-Fi credentials
- RFID initialization
- GPIO pins
- Web server
- Inventory database
Upload the firmware to the ESP32.
5Register RFID Tags
Scan each RFID card once and assign it to an inventory item such as:
- Component Box
- Laptop
- Tool Kit
- Spare Parts
- Office Equipment
Each RFID UID becomes the unique identifier for that item.
6Build the Web Dashboard
Create a lightweight dashboard that displays:
- Item Name
- RFID UID
- Entry Time
- Exit Time
- Current Status
- Total Inventory Count
The dashboard refreshes automatically whenever a new tag is scanned.
7Test the System
Present RFID tags near the reader.
Verify that:
- Tag is detected instantly
- Inventory updates correctly
- LEDs respond
- Buzzer activates
- Dashboard reflects changes in real time
8Design a Custom PCB
Once the prototype works reliably, design a custom PCB integrating:
- ESP32
- RC522 connector
- Power supply
- Status LEDs
- Buzzer
- Programming header
This creates a compact and professional hardware solution.
Himanshu Dada
