SPECS:
- ESP32 C6 Mini (Wifi 6, Thread, Zigbee, Matter)
- BQ25186 (Solar based lipo charging, power path)
- USB-C (programming, charging)
- QWIIC connector (i2c sensor connector)
- Reverse polarity protection on the solar panel input
- 10 IO pins (including 3.3v and VBUS)
- M2 mounting holes
- Target use case: Outdoor smart home sensors & remote IOT nodes
In the full video, you can see how I put it together, the challenges that I faced, and a real world test running running a sensor.
Narrow Studios
STEMinds
Colin McAllister
vincentmakes
Viet Dzung
