Why?
Building hardware prototypes usually means connecting dozens of wires, redesigning PCBs, and rebuilding the same circuits over and over again.
Molde explores a different approach.
The idea is to build a reusable hardware ecosystem where the same modules can be combined in many different ways without rebuilding the entire project.
The Concept
The system consists of two main parts:
Main Panel – the base platform that provides power, communication and mechanical support.
Modules – interchangeable functional blocks such as displays, sensors, buttons, joysticks, communication interfaces and other electronics.
Modules attach magnetically using pogo-pin connectors, allowing them to be installed or replaced in seconds.
Oleg
Aightech
benw
Hexabitz
