1Step 1
Yes I'm working on this: Instructions (in progress)
I'll start copying that over in a step by step manner. Hopefully this will allow me to get everything and in the correct order.
Step one: Setting up you Pi
This is a pretty good starting place to start setting up your Pi:
Headless Raspberry Pi Setup with Raspbian Jessie
When I setup my Pi I hadn't found this but he's solved the issue of starting SSH up as it's now disabled by default. You'll need your PC, an SD card reader, and the SD card (large enough to load the Raspian image).
Neil Cherry
