Hackaday.io Hackaday.io
Sign up Log in
OpenValve
OpenValve is the first 3D-printable irrigation valve. It only waters when plants need it, works in gravity-fed setups. (open-source)
fabianFabian
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
0
0
0
Team (1)
  • fabianFabian
Join this project's team
  • OpenValve
  • Project Website
ongoing project
This project was created on 08/04/2026 and last updated an hour ago.
Description
OpenValve is an open-source alternative to classic irrigation timers. Instead of watering on a fixed schedule, it measures soil moisture and opens when the soil becomes drier than a configurable threshold.
OpenValve is suitalbe for little greenhouses, balconies, plant beds and community gardens.
At its core is a 3D-printable, bistable pinch valve that consumes power only while switching. It works with gravity-fed water sources as well as pressurized systems up to 4 bar, tolerates particle-rich water, and runs for approximately three months on a 9 V battery.
The mechanical design, electronics, PCB, bill of materials, and software are open source, allowing OpenValve to be repaired, modified, or adapted for other sensor-controlled liquid-handling projects.
Details
Log In/Sign up to comment
Sign up with Github
OR
My goal was to create and share an open source water monitoring system that was capable of measuring water temperature, pH, and ORP.
Project Owner Contributor
Pool Water Quality Monitor
brian-chamberlainBrian Chamberlain
Open source irrigation for small scale agricultural operations.
EnviroFlux
sherveen-shokoohiSherveen Shokoohi
Industrial water-from-air generator. Zero electricity, pumps, filters, or brine. Uses 1km deep-sea thermal liana. 100% Open Source solution.
The Skoog Buoy: Zero-Electricity, Zero-Brine
goranskoogGoranskoog
A sub-$10, zero-power water purification platform utilizing passive acoustics, bio-aerogels, and piezoceramic plasma.
Autogenous Capillary-Plasma System (ACPS) Sub-$10
charles-clark-lawrenceCharles Clark Lawrence
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "OpenValve", please tell us the reason.
Send message
Remove Member
