11Step 3.5
Solder three BC337 transistors
12Solder PN532 module
13Step 4
Solder the male pins to the PN532 module
14Assemble
15Step 5.1
Add two heat inserts into 3d printed housing and add the diffuser; use glue for permanent attachment.
16Step 5.2
Attach the PN532 using two PCB standoffs
17Step 5.3
Add the main PCB and fix it with two M3 bolts
b.sverdlyuk
