1Solder prismo PCB instruction
2Step 1.1
Solder pins for ESP32-C3 Super mini to Prismo PCB
3Step 1.2
Solder the ESP32 board
Add a socket for PN532![]()
42. Soldering audio - add buzzer
The board has a small buzzer for sound effects; this step is also optional. The sound enhances the user experience.
5Step 2.1
Solder the buzzer and its resistor. You can control the buzzer's volume by choosing the right resistor. We recommend a 100 Ω resistor. For reference, the 1000 Ω resistor makes the buzzer really quiet, so you can hear it only in completely silent environments.
6Solder light components
The light line connects to the 5V line and is controlled via 3 transistors.
7Step 3.1
Solder four RKGB LED diodes. Use diodes with a common cathode. Match the long (cathode) pin on the diode with the board GND. The other side of the board is labeled RKGB; the letters match the LED diode pinout.
8Step 3.2
Solder four 150 Ω resistors for the red line
9Step 3.3
Solder four 100 Ω resistors for the green and blue lines
10Step 3.4
Solder three 1000 Ω resistors to the light board output.
b.sverdlyuk
