A 30-Year-Old Guitar Amp Circuit Stores Neural Network Weights
— DTL Ternary Cell, Public Domain
The same DTL circuit I designed in the 1990s for 3-channel tube amplifier
footswitching is a ternary memory cell storing {-1, 0, +1} neural network
weights — one transistor per weight, no clock, no refresh, 30 years of
production hardware behind it.
I designed this circuit in the 1990s for a 3-channel tube amplifier.
Channel A. Channel B. Channel C. One button selects any channel directly
from any other — one press, no intermediate off state. One green LED on
at all times. The switching is instant, clean, and glitch-free inside a
100-watt tube amp chassis — one of the most electrically hostile
environments you can put a low-level switching circuit into.
I have built 3-way, 4-way, and 6-way versions. All in production. All
deployed in real amplifiers.
In 2026 I recognized it as something else.
WHAT THE CIRCUIT IS
Three positions. One transistor always conducting. The switching is done
by the diode array operating on unbalanced contact potential — not by the
transistors. The transistors are output stages. The diodes make the
decision.
Each position: B+ through a pull-up resistor to a node. From that node:
one diode to its own transistor base, and diode connections to all other
positions' collectors.
When position 1 is active (transistor conducting, collector LOW):
  Active collector LOW + one diode drop  =  ~0.8V at positions 2 and 3
  Two diode drops required to drive base  =  ~1.2V minimum threshold
  0.8V < 1.2V — positions 2 and 3 cannot conduct
The two inactive collectors are HIGH. Those two HIGH collectors feed
current through their diodes back to position 1's base — sustaining it
above threshold. Position 1 holds indefinitely. No clock. No stored
charge. No capacitor. No external hold signal.
One transistor always conducts. One current path: B+ → R → collector → GND.
The designer sets R. The designer sets the margin. The gap between 0.8V
and 1.2V is the hold. Supply voltage controls immunity.
WHY IT IS TERNARY
Three stable states. One always active. Position is meaning.
  Position 1 active  =  {-1}   negative weight
  Position 2 active  =  {0}    zero weight
  Position 3 active  =  {+1}   positive weight
This is exactly the ternary quantization scheme used in ternary neural
network inference — including Microsoft's BitNet b1.58 and related
architectures. Every weight in a ternary-quantized model is one of
{-1, 0, +1}. One DTL cell stores exactly one weight. One transistor.
No binary encoding. No decode. Position is the value.
Compare to binary SRAM:
  SRAM stores one weight value in 7-8 flip-flops = 42-48 transistors.
  DTL ternary stores the same value in 1 transistor.
  No clock. No refresh. No forbidden state.
N-ARY BY NATURE
The circuit does not have a preferred base. The diode contact potential
mechanism works identically for any N.
  N=2:    binary flip-flop. No clock. No forbidden state.
  N=3:    ternary trit. {-1, 0, +1}. One transistor per neural weight.
  N=4:    ternary plus idle. Position 4 = weight not loaded.
  N=6:    six-position selector. Built and deployed in hardware.
  N=18:   LTSpice verified (CYR_OneHot_18way_v3.cir).
  N=128:  one-hot ASCII storage. Full character set. One transistor per
          character. Detailed in the previous Hackaday release:
