S100 bubble memory board from Byte magazine 1984
Bubble memory article from Byte magazine 1984
0 followers
Not my project, I have not made it, nor plan to do so, but it might interest the S100 crowd.
I scraped the article from the magazine into a single pdf file, and OCRd the source code into something that assembles online at asm80.com. I checked the hex output is correct yet. I have nothing to test it on, so I can't say if it works.
I also grabbed the bubble memory chapter of the intel 1984 data book. There is code for the 8085 and 8086. I have not OCRd that.
BUBBLE-MEMORY-ON-THE-S100-BUS.pdf
From Byte magazine, 1984.
Adobe Portable Document Format - 17.27 MB - 08/19/2026 at 03:41
Preview
bubble_test.bas.txt
The test program in BASIC. OCRd but untested.
plain - 2.17 kB - 08/27/2026 at 13:08
Download
bubble_1.a80.txt
8085 assembly code. Assembles online at asm80.com, but untested.
plain - 8.48 kB - 08/27/2026 at 13:08
Download
bubble_2.a80.txt
plain - 2.98 kB - 08/27/2026 at 13:08
Download
bubble_patch.a80.txt
text/plain - 7.79 kB - 08/19/2026 at 03:45
Download
View all 6 files
Craig wrote 7 days ago point
Thanks Keith for finding and archiving this information.  I have not sent boards off for fab in months, in fact I have forgotten what all is in my board queue…. but when I finally do I will try to include this s100 bubble board.. or more likely a version of it that has the bubble components directly onboard rather than using the bubble kit board kludge-on. Just to make it a cleaner build.  That is unless someone else  gets the itch to layout the board before I do.  Between the code I already have written for my bubble board and the code in Byte, getting it up and going shouldn’t involve too much gnashing of teeth.   I have bubbles if you ever feel the need.
