Bubble memory article from Byte magazine 1984
BUBBLE-MEMORY-ON-THE-S100-BUS.pdfFrom Byte magazine, 1984.Adobe Portable Document Format - 17.27 MB - 08/19/2026 at 03:41 |
bubble_test.bas.txtThe test program in BASIC. OCRd but untested.plain - 2.17 kB - 08/27/2026 at 13:08 |
bubble_1.a80.txt8085 assembly code. Assembles online at asm80.com, but untested.plain - 8.48 kB - 08/27/2026 at 13:08 |
bubble_2.a80.txt8085 assembly code. Assembles online at asm80.com, but untested.plain - 2.98 kB - 08/27/2026 at 13:08 |
bubble_patch.a80.txt8085 assembly code. Assembles online at asm80.com, but untested.text/plain - 7.79 kB - 08/19/2026 at 03:45 |
Thanks Keith for finding and archiving this information. I have not sent boards off for fab in months, in fact I have forgotten what all is in my board queue…. but when I finally do I will try to include this s100 bubble board.. or more likely a version of it that has the bubble components directly onboard rather than using the bubble kit board kludge-on. Just to make it a cleaner build. That is unless someone else gets the itch to layout the board before I do. Between the code I already have written for my bubble board and the code in Byte, getting it up and going shouldn’t involve too much gnashing of teeth. I have bubbles if you ever feel the need.
