You can check out the project on GitHub.
This board is designed for my pick-and-place machine. It might also work on an FDM 3D printer, because in my plan the PnP machine is derived from a box-style printer (for example a Voron). I am not sure yet whether that part is fully feasible.
Why I'm building this:
One day I had to place a lot of 0603 SMD parts onto a PCB with tweezers. It was exhausting. Later boards may use 0402 as well. Sending a small batch (two or three boards) to a PCBA house costs too much. I wanted to buy a pick-and-place machine, but commercial machines are far beyond my budget, so I decided to build one myself. When I looked at open-source PnP machines, most of them were flat 2D layouts. With many feeders they take too much desk space. So I decided to build a box-style pick-and-place machine from scratch. That is why this project exists.
Hardware:
The three cores are STM32H745XIH6 (MCU), XC7A35T-2CSG325C (FPGA), and V851S (MPU).
I chose this trio because I want mixed alignment: pure optical alignment for simple parts (0805, 0402, and similar packages), and a vision camera (OpenCV-style) for complex parts. I also want up-looking / down-looking cameras plus on-device AI for machine-health checks — that is why V851S is in the mix.
I am using pure optical alignment on simple parts because I want industrial on-the-fly ("flying shot") speed, and the vision hardware that can actually do that is far too expensive. Optical alignment is much cheaper, but it needs real-time performance. The machine is meant to be a box-style CoreXY so it takes less floor space (like a Voron printer). The box-type feeders work like a small parts warehouse: during a job, parts are brought down to the bottom and dispensed from there. The moving head can also travel to a zone tens of centimeters above the work platform to change tools (nozzles and other accessories). That means a lot of structure and a lot of stepper motors to control. Closed-loop steppers with the servo drive in the motor base are too expensive for me, and the cheap ones are not fast enough. An FPGA can handle that and more — I want the finished machine to be strong, not merely usable. That is how this three-core combination ended up here.
This hardware cannot run OpenPnP smoothly, so I have two approaches:
1. I reserved a PCIe 2.1 ×2 link for another board that would run OpenPnP (it sits in a PCIe ×4 slot, wired to the FPGA). XC7A35T-2CSG325C actually supports PCIe 2.1 ×4, but honestly I am not confident I can make that work yet. So I will not aim that high for now — maybe later.
2. Another way to measure component offset without OpenCV.
First, a camera detects the part (the camera is connected directly to the MPU). I have two design options; I prefer the second. Both use a small AI model to detect orientation (0°, 90°, 180°, or 270°). Everything below happens after Step 0.
Here are the actual steps (flowchart first, then the explanation):
① The nozzle picks up the part and moves to a laser light curtain near the feeder (light curtain 1).
② When light curtain 1 is blocked by the part, lock X = c.
③ When the part leaves light curtain 1, lock X = d.
④ Rotate θ degrees.
⑤ When light curtain 1 is blocked by the part, lock X = e.
However, knowing only these values is not enough to calculate the XY and angular offsets. Therefore, when a component type is used on this machine for the first time, it will go through the following steps, and the final results will be saved.
① The nozzle picks up the part and moves to light curtain 1.
② When light curtain 1 is blocked by the part, lock X = f.
③ When the part leaves light curtain 1, lock X = g. And save |f − g|.
④ Rotate α degrees (this value is small like 0.9 degrees or smaller) and moves to light curtain 1.
⑤ When light curtain 1 is blocked by the part, lock X = h.
⑥ When the part leaves light...
Shin Lin
jason.gullickson
Adam Munich
ZeptoBit
Owen Trueblood
