Log #2 — STM32 power supply
6 hours ago • 0 commentsAfter the overall power tree was roughly settled, I started with the MCU power supply. I want the MCU to handle low-level monitoring and management for the whole board.
I am not using a PMIC for power sequencing. The board has many chips that need different voltages, and some rails are shared. A PMIC would take a lot of board area, and it is hard to find one that matches everything. So I merged rails at the same voltage and use load switches to control power-up.
Without a PMIC, something still has to control the sequence. I gave that job to the MCU. One reason is that I do not need a complex bring-up path for the STM32 itself: with USB disabled and VREF on the internal reference, it can boot from a single 3.3 V rail. Another reason is that USB is not used on the MCU in my design (USB goes to the V851S). I only need to monitor each rail coming up, so ultra-high precision is not required.
Current progress: the basic MCU power-on circuit is drawn. Power sequencing control is not in the schematic yet.
MCU power schematic:
Log #1 — Architecture: boot sequencing and the 24 V power tree
08/20/2026 at 07:05 • 0 commentsI did not expect it would take two months before I started posting logs on Hackaday. Since two months have already passed, I will just record what got done in that time.
After the chip selection was frozen, the first real headache was power-on sequencing. If the FPGA controls the sequence, who sequences the FPGA? Handing it to the MPU did not feel stable enough, and I have not seen people do it that way. So I gave it to the MCU — STM32H745XIH6. With proper protection it can still boot safely and handle emergencies.
The plan is: the M4 core plus the FPGA watch hardware status for the whole board and the whole machine, and respond. The M7 core runs on its own: signal processing, computation, and logic. In short, the STM32 owns the earliest sequencing.
Next is power. I plan to feed the whole motherboard from 24 V. First I built a simple protection circuit with a P-MOSFET:
After that, two TI TPS56637 parts do 24 V → 12 V (for the PCIe slot) and 24 V → 5 V (the board bus). Four SY8843 bucks then make 1.0 V, 0.9 V, 1.5 V, and 3.3 V. From 3.3 V, RT9013-12 / RT9013-15 LDO parts make 1.2 V and 1.5 V.
Once every rail exists, four TPS22966 load switches, driven by the MCU boot code, bring the different cores up in order.
Photos of the power tree:
Shin Lin
