Smart Weight Scale Machine based one ESP32
It is built around the ESP32 microcontroller. Unlike a traditional weighing scale that only displays weight this can send wirelessly data
Public Chat
Introduction
This project is a smart weighing machine designed using an ESP32 microcontroller, a load cell, and an HX711 amplifier module. The system measures the weight of vegetables or other products and wirelessly transmits the data to a custom Flutter mobile application.
The idea behind this project was to modernize conventional weighing scales by adding wireless connectivity and a smartphone-based user interface. Such a system can be useful for vegetable vendors, grocery shops, small retail businesses, and inventory management applications.
System Architecture
The load cell converts the applied force into a small electrical signal. Since this signal is extremely small, the HX711 amplifier module is used to amplify and digitize the signal.
The ESP32 continuously reads the weight data from the HX711 module, processes the readings, applies calibration factors, and calculates the final weight value.
The processed data is then transmitted wirelessly to a Flutter mobile application where the user can view the measured weight and corresponding price information in real time.
Working Principle
  1. An object is placed on the weighing platform.
  2. The load cell senses the applied force.
  3. HX711 amplifies and converts the signal into digital data.
  4. ESP32 reads and processes the measurement.
  5. The calculated weight is sent to the Flutter application.
  6. The application displays the weight and calculated price instantly.
Mobile Application
A custom Flutter application was developed for this project. The app receives weight data from the ESP32 and displays it in a user-friendly interface.
The application can be extended in the future to support:
  • Sales records
  • Customer billing
  • Cloud synchronization
  • Inventory management
  • Historical data storage
Applications
  • Vegetable Shops
  • Grocery Stores
  • Small Retail Businesses
  • Warehouse Monitoring
  • Smart IoT Weighing Systems
app-release.apk
Android app for weight scale
package-archive - 15.21 MB - 08/26/2026 at 07:05
Download
  • 1 × esp32 wroom
  • 1 × Load Cell 10 kg load cell
  • 1 × HX711 Load Cell Amplifier
  • 1 × Li Ion battery 18056 type
  • 1 × AMS117 3V3 LDO
View all 8 components
  • 1
    Gather Components
    Required components:
    • ESP32 module
    • Load Cell
    • HX711 Load Cell Amplifier
    • Jumper Wires
    • Power Supply
    • Android Smartphone
    • Flutter Mobile Application (apk can be found under files section in this project)
  • 2
    Connect the Hardware
    Connect the load cell to the HX711 amplifier module according to the load cell wiring colors.
    Connect HX711 to ESP32: as per wiring diagram given in the diagram in this project.
    (Modify pin numbers according to your firmware, if needed.)
  • 3
    Program the ESP32
    Install Platform IO extension in VSCode
    1. Upload the firmware to the ESP32.
    2. Open the Serial Monitor and verify weight readings.
View all 7 instructions
