1Gather Components
Required components:
- ESP32 module
- Load Cell
- HX711 Load Cell Amplifier
- Jumper Wires
- Power Supply
- Android Smartphone
- Flutter Mobile Application (apk can be found under files section in this project)
2Connect the Hardware
Connect the load cell to the HX711 amplifier module according to the load cell wiring colors.
Connect HX711 to ESP32: as per wiring diagram given in the diagram in this project.
(Modify pin numbers according to your firmware, if needed.)
3Program the ESP32
Install Platform IO extension in VSCode
- Upload the firmware to the ESP32.
- Open the Serial Monitor and verify weight readings.
4Calibrate the Load Cell
- Power on the system.
- Perform tare calibration with no load.
- Place a known weight on the platform.
- Adjust the calibration factor until the displayed value matches the actual weight.
5Install the Mobile Application
- Install the Flutter application on an Android device.
- Enable location for bluetooth communication.
- Connect the application to the ESP32.
6Test the System
- Place an object on the weighing platform.
- Observe the measured weight.
- Verify that the value is updated in the mobile application.
- Check the calculated price output.
7Final Assembly
- Secure all electronics inside the enclosure.
- Mount the load cell firmly to the weighing platform.
- Route wiring safely.
- Perform final calibration and testing.
The Smart Weight Scale Machine is now ready for operation.
