Electroprint
A software tool to help design 3D printed PCBs
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Electroprint is a software designed to merge 3D files with EDA (Kicad) netlists to 3D print objects with integrated electronics.
Merge KiCad netlists with 3D printed parts to facilitate the integration of electronics into FDM fabrications, using the good old "print-in-place" method.
I decided to work on this software when I tested carbon-nanotubes infused PLA.
The software allow:
-Import of a 3D model (stl or step)
-Import of Kicad netlist
-Generate 3D footprints (provided you have Kicad installed and it's footprints folder)
-Positioning of component's footprints
-Routing in 3D (horizontally and vertically)
-Export step or 3MF with included pauses for your FDM slicer
Video tutorial provided in external links
