I have written about why I built it and my many failures along the way and other stuff at: https://www.thetubecomputer.com/
All the tecky stuff is on the second page along with the new instruction set.
I have wondered if this is actually "retro" as it is not a copy of something old but a new vacuum tube computer. Just built with old recycled vacuum tubes but using the same hardware methodology as back in the 1950s with all the passive components under the tubes. Also the software is more 70s than 50s, so that t can be used as a general purpose computer. I hope it is retro, at least in a general sense!
Mike
Quinn
Keith
bfoz
carbono.silício
Check out the IBM 704 or 709 vacuum tube computers at the Computer History Museum in Mountain View, CA. They have a clam shell design. I have been inside them. On the outside there is a "wall" of vacuum tube modules behind clear, plastic sheets. On the inside there is yellow wire connecting the modules. I think the tubes are on the outside so one can see any that have failed.
