Real-Time ECG Heart Monitor (Arduino & Processing)
Back to overview
A beautiful, real-time heartbeat visualizer built with an Arduino Uno, a Pulse Sensor, and Processing. Features a pure ASMR build process!
  • 4
    Running the Processing Visualizer
  • 1. Open the .pde file in the Processing IDE.
  • 2. Look for the serial port configuration line in the code (e.g., myPort = new Serial(this, "COM3", 9600);).
  • 3. Change the COM port name inside the quotation marks to match the exact COM port your Arduino is using.
  • 4. Click the Run button.
  • 5
    Testing the System
    A new visualizer window will open. Gently place your index finger on the Pulse Sensor (don't press too hard, or you will restrict the blood flow). Within seconds, you will see a real-time red line tracing your heartbeat, just like a real medical ECG monitor!
  • Discussions
